International Layer System
- This topic has 8 replies, 5 voices, and was last updated 21 years, 8 months ago by
keating.
AuthorPosts
June 24, 2004 at 10:43 am #707178
InactiveDoes anyone know of a good layer system for an Arch office to use? I know there’s the international layer system, but can anyone recommend it?
Any comments regarding large no. of layers versus usability?
July 5, 2004 at 4:54 pm #743812
Plug
ParticipantBritish standard BS 1192-5:1998 covers general guidlines for construction cad drawings, layers, linetypes etc. You can order it from British Standards Online.
July 6, 2004 at 5:15 pm #743813
ParticipantI used the BS system before. Its OK in a large practice when everyone tries to use it. Its not very obvious (or doesnt even hint towards) what element is on what layer. There is a simplified version at the back of the RIAI good practice guide – looks pretty user friendly to me.
July 7, 2004 at 2:00 pm #743814
Plug
ParticipantHow does one go about getting a copy of the RIAI guide ?
July 14, 2004 at 12:54 pm #743815
InactiveI’ve looked a bit more into all this…The RIAI guide (the RIAI Good Practice Guide) mentions the CITA layering system. (‘Plug’, just ring the RIAI for a copy of their guide).
CITA (http://www.cita.ie) were setup in 2001 to establish standards for use of IT in the construction industry. While these are not BSI (British) or NSAI (Irish) standards, at least there are a number of important construction industry members involved.
They appear to be trying to get many of the Councils onboard with this system and lead from there. So far they seem to have a few…and as they have the RIAI, IEI, CIF, etc onboard, I guess it can only improve.
Levels are like…
AA – WALL – INTN – 04
…so Architectural, Walls, Internal, pen weight 04
It’s intended to set a standard for the whole industry, so for example structural levels would begin with SE, mechanical with ME, electrical with EE, etc. Seems quite good.
Has anyone used this system before?? Any probs with it?
July 14, 2004 at 1:57 pm #743816
keating
ParticipantCostomised systems are best as each office has a different methods of bringing documentation from planning to as-built. Compliance with any system can be managed by having all layers on a pull down menu , all linetypes and colours are by-layer. Layers are catagorised by discipline followed by element, then material, scale, new exist , demo. Sub catagories can go on indefinately depending on the size of the project. A simple project could have for example A-text-050 a large project could have A-zone_B-concrete-setdown-text-000. Drawings can be filtered to show only zone b elements, only concrete elements, the number refers to the scale details will be represented at, 000 means all scales.
With a well designed system, drawing model can be draw orthaganally, All plans have the same origin and sections and elevations are drawn perpendicular to the grid. Details are overlaid on large scale sections.
Cad drawings match hardcopies in that if i look for cad drawing a-156 it is called a-156.dwg and is a single titleblock with the CAD model referenced in. An investment of time in setting up a proper system pays dividends, especially with high staff turnover. -
July 14, 2004 at 3:08 pm #743817
FIN
Participantthe layer system u have sounds very long winded to be honest but completely agree with the hard copy being named the same as cad copy
July 14, 2004 at 5:18 pm #743818
InactiveKeating, the system you are describing sounds like the International Standard system (ISO 13567-1,2,3). I looked into this, but have to agree with Fin – it seemed very complicated also. It would work superbly I’m sure, but the Arch office would have to be immaculate with its implementation and use, and I just know that it would not work in my office. Despite having some international projects, I also felt that unless those offices also used the same layer system, there was no absolute need for using this system, and so a more user-friendly, Irish system (the CITA system) would be of more use.
…Keating, I’m not sure exactly what you mean by this, but sounds interesting…could you explain more?
Are you also saying that you’d have a little thumbnail of the overall drawing in the titleblock? Sounds like a good idea.
I agree in principle with the idea of the hard copy and virtual copy being named the same, but do you not find it awkward to know what is what when scrolling down the list in the computer…esp when taking over a proj from someone else? Perhaps a better system would be to call it “a-156_GroundFloorPlan-Zone1” or something?
July 15, 2004 at 2:36 pm #743819
keating
ParticipantI used this system with a large international shopping centre developement company. The layer system was rigourously policed and it was quite complicated to get the hang of at the start. Unique sets drawings were produced for each trade, many x-refs were used, for instance individual drawings for 1. grids. 2 columns 3. blockwork 4. doors etc would be referenced into the drawing you were working on say floor finishes, this meant that many designers could work on the same plan simultainiously. Consultants drawings would be refernced in to show structure or M+E with co-existant origin and grids. References were brought in using a costomised dialogue box. In one drawing I had 40 references, yes complicated but worth it. I worked on precast and glazing for the entire perimeter and designed shop standard details of every component just by using the CAD model, communication was through the model, if you wanted it to be built, you drew it, simultainously the structural engineer updates the structural drawings, the fit out guys adjust their layout and when you look out the window you can almost see it being built. 15 architects, (5 or more irish) documented a job twice the size of Dundrum in 14 months and it was built in 13.
Orthaganol projection. if you reference the section/ elevation into the plan or vice versa, the walls and grid on plan line up with the section. Try it set up a site boundry and put a grid on it, Norting and eastings are your x+y grid andwill have an origin point, this will correspond with 0,0 on your CAD coordinate system. Next set up elevation and section grids. If you cut a section through east elevation looking north then you need to set up an elevation grid for it, it goes above the north boundry and its x gridlines correspond with plans, any sections or plans drawn looking north will sit on this grid, grids are set up for all directions you are viewing. One person administers site boundary and grid drawing, coz it is critical to the liason between site setting out and CAD drawing representation. You have a key of the overall plan or elevation/section in the corner of the titleblock. Hee haw agree with the drawing number-naming, i just like to cut out the practice of having 3 titleblocks on one cad file or having details copied to the side and worked on for a fax. Drawing numbering now is being dictated by web hosting systems anyway.
I hope i havn’t cause even more confusion, to restate my original point a bit better, a one size fits all solution for ireland needs to reconcile the conflicting requirement of flexibility for a diverse workload and strick adherence to protocol for consistancy.
AuthorPosts
