dublin city ground level
- This topic has 10 replies, 7 voices, and was last updated 17 years, 8 months ago by
- January 28, 2008 at 1:37 pm #709809
Maskhadov
ParticipantCan you find the lay of the land including hills etc inside the m50 anywhere ?
- January 28, 2008 at 3:51 pm #797179
Inactivea discovery series map from the Ordnance Survey will give you contours at 5 or 10 metre intervals.
- January 28, 2008 at 4:09 pm #797180
InactiveAnd all 1:1000 town maps have spot heights and benchmarks on them. Probably the 1:2500 series too, but I couldn’t be sure.
You might have to join the dots yourself, though!
- January 28, 2008 at 4:27 pm #797181
Inactivethanks for that. !
- January 28, 2008 at 4:52 pm #797182
Inactiveanother option is to go on to google earth, turn on terrain and then look at it from a low angle.
- January 28, 2008 at 8:40 pm #797183
Inactivei wish it was a bit more 3 d with google earth.
- January 28, 2008 at 8:54 pm #797184
Inactivecheck out carrauntoohill, it’s mapped in huge detail.
- January 29, 2008 at 10:51 am #797185
InactiveYou could use
Earthtools
Make sure to click on contour map.Flood maps is worth a look too – but that is designed specifically for illustrating the effect of sea rise (actually don’t look at that – unless you live in the hills you’ll get upset. docklands anyone?)
If you only need to check a few specific points you could use a route planner that uses height info – try mapitpronto
How accurate do you need – there’s very detailed info available but it’s licensed. Used for (mobile phone) network planning, surveying etc…
- January 29, 2008 at 12:37 pm #797186
Woo hoo, 7m rise and i got me a sea front property!!!
- January 29, 2008 at 3:46 pm #797187
InactiveAn interesting curiosity – if you have the opportunity – is the former remains of the former St Mary’s Abbey behind Capel Street. A remaining chapter house building was been incorporated into a Georgian builidng but remains very well preserved and its well worth a look. An interesting feature is that its about 2m below ground level from the entrance on Meetinghouse Lane. The guide noted that this is because the actual ground level of the city has risen by 2m since the abbey was founded and built in the middle ages.
- February 19, 2008 at 9:59 pm #797188
Inactivethanks !! I was looking for something pretty accurate like the rise and fall of land level to the nearest square meter ( like those spot heights on the ordance survey maps)
