boundary wall
Home Forums Ireland boundary wall
Viewing 11 reply threads
    • #710525
      tooler
      Hi wonder if anyone can help?
      I live next to a school. There is a high boundary wall between us. I am building a shed which is INSIDE my side and is not attached to the boundary wall.
      The roof is apex and I am putting PVC Sofffit/facia and guttering. The school has objected to my shed as they claim water is running down into their property from my shed roof; as I haven#t yet had a chance to put guttering on. They also say that if I put guttering on it will br over THEIR boundary wall and will be a danger to the kids??
      Are there any rules/laws covering this.:mad:
    • #807095
      Very basically you cannot go building/adding things on their side of the wall (e.g. gutters, fascias and soffits) without their permission – it’s called trespass!
    • #807096
      what DOC said. if you put a gutter or your building overhangs their property at all it is an illegal development. depending on the location, you should not be building right up to the boundary wall anyway.
    • #807097
      thanks guys; why cant I build up to the boundry I am not attaching anything to it??:rolleyes:
    • #807098
      so you are not using the boundary wall at all??? does it form any part of this new shed??
      if not then as long as you gutter doesnt extend over half of the boundary wall you are fine…
      conventionally, the halfway point of the boundary wall is the actual boundary…
    • #807099
      thanks henno; no nothing is attached to the boundry wall at all; I have cut the rafters back and replace the siffit/facia and guttering is now halfway and is not resting/touching the wall. I hope this will do!:rolleyes:
    • #807100
      Be careful now!
      Boundary/party walls are weird leagl entities! Both parties whollly own the entire wall (not just half the wall or up to the halfway point) but the wall is mutually exclusive, i.e. no party can do anything to the wall without the others consent.
      I am quite the boundary wall expert. :p (having been involved in a 5 year courtcase over one – on the right side of course!).
    • #807101
      @DOC wrote:
      Be careful now!
      just to clarify, the OP stated he wasnt ‘doing’ anything to the wall…. therefore i was making the point that the halfway point of the boundary is the notional vertical plane of the boundary… therefore i was advising to ensure that nothing extended beyond this plane…
      is this not correct??
      is there any other legal quirks that are applicable to boundary walls??
    • #807102
      I understand what DOC is saying;; usually it appears that the center line is considered the main point of concern; however it is possible that the wall could be wholly built on one persons property; however as the foundation of this wall is a good 8″ into my property I doubt this to be the case in this instance;
      A surveyor friend has indicated that I should stay on the center line and no further.
    • #807103
      Does anyone have a link regarding the law and rear extentions. (Friends neighbour is currently building, windows over looking her garden).
    • #807104
      If your friend’s neighbour has planning permission, then
      not much can be done if neighbour had not objected
      at the time to the Council.
      If the development is carried out without planning permission,
      then one of the rules for exemption from planning states that,
      a first floor window should be minimum of 11m from boundary.
    • #807105
      It’s just a single story extention but their garden is slightly elevated so the extentions two boundry side windows will look across and down into her garden. Was thinking of erecting trellis against her side of the boundry wall as a screen. I don’t think your allowed raise the height of the wall but I wonder what the story is with such a ‘solution’ ?
