TGD M Question
TGD M Question
Do all newly built homes require a wheelchair accessible toilet, thanks.
- aypc43
Re: TGD M Question
Depends on your lingo
At least you can download part m for free enjoy it and ambulate it...
Re: TGD M Question
aypc43 wrote:Do all newly built homes require a wheelchair accessible toilet, thanks.
yes
http://www.environ.ie/en/Publications/DevelopmentandHousing/BuildingStandards/FileDownLoad,1655,en.pdf
unless the floor plate at entry level is less than 45sqm when you can drop down to an ambulant loo
- wearnicehats
Re: TGD M Question
Well......there is the anomaly about duplex apartments where some local authorities insist on a wheelchair accessible WC at the top of a flight of stairs whereas some accept that the provision of an ambulant accessible loo is acceptable. The regulation is framed in such a way to allow you argue both ways.
- corkblow-in
Re: TGD M Question
corkblow-in wrote:Well......there is the anomaly about duplex apartments where some local authorities insist on a wheelchair accessible WC at the top of a flight of stairs whereas some accept that the provision of an ambulant accessible loo is acceptable. The regulation is framed in such a way to allow you argue both ways.
really? never seen that - I have always put the accessible wc at entry level in a duplex. Mind you, I always make the upstairs bathroom accessible too.
Unless you've no habitable rooms at entry level in which case the toilet goes on the same floor as the living room. Usually the 45sqm rule helps in duplexes
- wearnicehats
