Dublin Castle - Who is in Charge?
Re: Dublin Castle - Who is in Charge?
Postby exene1 » Thu Apr 18, 2013 3:32 pm
Typically of the time, the Palace Street / Dame Street block stood semi-demolished for years as the 1975 newspaper piece says, rather than being quickly demolished to widen out the street ... What a sorry saga Dublin was back then ... Here is a grab from a clip of 8mm film taken about 1970 - from of all places a menu bar in the 2003 Led Zeppelin retrospective DVD - where you can see the same situation as in the pic in the newspaper clipping, with buildings demolished to first-floor level (following fire in the case of the corner building(s)) plus maybe one or two of the terrace still standing at the City Hall end:
From Dublin city libraries:
exene1
Postby StephenC » Fri Aug 30, 2013 11:48 am
A Part VIII planning application has been lodged to convert the ground floor of 3 Palace Street (so called 'robocop' building) to use as a Dubline visitor centre, and to redesign Barnardos Square
http://www.dublincity.ie/swiftlg/apas/r ... ts%3C/a%3E
Postby fergalr » Fri Aug 30, 2013 5:25 pm
AKA "We've no idea what else to do with a building we should never have built".
Postby StephenC » Tue Sep 17, 2013 2:48 pm
A couple of interesting comments on this application. Submissions now closed.
Postby StephenC » Mon Oct 14, 2013 7:12 pm
Punchbowl wrote:Deckhands wanted: Apply within
This 'humble' addition to Ireland's EU presidency is to finally be removed the weekend after next. €20k later.
Postby fergalr » Tue Oct 15, 2013 3:50 pm
Did they just put it up so the ministerial drivers would know where to go?
"Just past Robocop, take a left at the flags."
Postby missarchi » Thu Oct 17, 2013 1:44 am
The real reason for these flag poles was "security issues"
Postby Paul Clerkin » Thu Oct 17, 2013 4:18 pm
They're probably historic now... we should save them...
Postby wearnicehats » Fri Oct 18, 2013 11:05 am
nailed it
great work lads. Time for a Bulmers
http://www.broadsheet.ie/2013/10/18/as- ... een-there/
Previous
