T2 & Pier D Images
T2 & Pier D Images
Postby Flyboy » Thu Jun 26, 2008 9:31 pm
The DAA has put new new construction images of T2 on its website. They also have shots of Pier D at Dublin Airport. Pictures are in the Image Bank area
http://www.dublinairportauthority.com/TDA/Overview/
Flyboy
Re: T2 & Pier D Images
Postby ForzaIrlanda » Thu Jun 26, 2008 10:53 pm
T2 seems to be progressing fairly well, I've been through Dub Airport twice in the last month and its moving fairly quickly. Pier D is also very nice (a long bloody walk) but spacious and bright which is nice (also there's a bar down there :)) but the only problem is that the signs showin gate numbers are really small.Still I think pier D is quite a well designed extension to the airport.
ForzaIrlanda
Postby adhoc » Fri Jun 27, 2008 8:15 am
Also, the DAA have applied to An Bord Pleanala for permission to build an extension to Pier D, i.e. they are seeking a declaration that such permission falls under the Strategic Infrastrure process and can bypass Fingal's planning processes. The extension will add 7 new gates and will be a continuation of the current building.
adhoc
Postby darkman » Mon Jul 14, 2008 12:19 pm
http://www.flickr.com/photos/34886552@N00/2658441544/sizes/o/
They will have to rearrange the roads before they can start on the front section.
darkman
Postby fergalr » Mon Jul 14, 2008 3:25 pm
ForzaIrlanda wrote:also there's a bar down there :)
Oh, it's a very classy little bar until you glance upwards and realise that they never fitted a ceiling. It's just pipes and other usually hidden paraphenalia :p
Postby johnny21 » Fri Jul 25, 2008 1:56 pm
T2 airport hotel
johnny21
Postby darkman » Fri Aug 01, 2008 8:10 pm
More DAA back slapping in the new T2 video for August
http://www.dublinairportauthority.com/TDA/Image_Bank/T2_video_010808.mpg
(press play)
like the terminal though:)
darkman
Postby archipig » Tue Aug 12, 2008 11:57 pm
Is this the actual cladding that will be onTerminal 2?
archipig
Postby archipig » Wed Aug 13, 2008 2:56 pm
On second inspection, the above image does not seem to show the outer skin of terminal 2.
archipig
Postby missarchi » Wed Aug 13, 2008 3:22 pm
insulation?
Postby darkman » Thu Aug 14, 2008 5:27 pm
I found floor plans for the new terminal on the Fingal Co Co website if anyone is interested.
planning application is F06A/1248 on http://www.fingalcoco.ie
There is a document called 'Floor Plans' on one of the pages which details everything, it's 50MB though. Check in will be on the ground floor (with the baggage hall behind), departures hall/security on the second floor, with baggage reclaim and arrivals on the first floor.
darkman
Postby Flyboy » Mon Aug 18, 2008 3:50 pm
archipig wrote:Is this the actual cladding that will be onTerminal 2?
There's some info on the cladding here. That looks like the first layer maybe.
http://www.dublinairportauthority.com/TDA/Latest_News/150808_cladding.html
Flyboy
Postby johnny21 » Tue Oct 28, 2008 3:25 pm
T2 progressing well.... pics from daa website
dublin airport.jpg (182.95 KiB) Viewed 2291 times
johnny21
Postby archipig » Wed Oct 29, 2008 1:45 am
More pictures of Terminal 2:
archipig
Postby Flyboy » Fri Nov 14, 2008 10:11 am
There's new timelapse footage of T2 construction on the DAA site.
Hi-res timelapse is here http://www.dublinairportauthority.com/TDA/FAQs/timelapse_high.html or click here http://www.dublinairportauthority.com/TDA/FAQs/timelapse_low.html for a lower res version.
Flyboy
Postby Peter Fitz » Fri Nov 14, 2008 11:22 am
Construction has started on the check in building (facing the main T2 structure) the alignment for the road to T1 between the two structures is now clearly visible.
Postby Bluetonic » Mon Nov 17, 2008 9:24 am
Peter Fitz wrote:Construction has started on the check in building (facing the main T2 structure) the alignment for the road to T1 between the two structures is now clearly visible.
They are a month in at this stage alright. Looks like they are making good progress as per seen last week by myself.
http://www.dublinairportauthority.com/TDA/Latest_News/131008_steel.html
The first elements of the steel structure for the T2 check-in hall at Dublin Airport were erected this afternoon.
The check-in hall for Terminal Two is located in front of the main T2 terminal building, which is now well under construction.
T2 contractor Watson Steel lifted the first steel column for the check-in hall into position at about 3.20pm this afternoon, having earlier unloaded several truck loads of steel at the check-in hall site.
Over the past six months, the steel frame of T2’s main passenger terminal has transformed the airport skyline. But with the check-in hall now beginning to take shape, the full design of Terminal Two will become more obvious to both passengers and staff.
Steel erection began at T2 on March 31, when the first elements of the baggage hall were lifted into position. Work began on the frame of the terminal proper in May.
October 13, 2008
Bluetonic
Postby Global Citizen » Thu Dec 04, 2008 7:45 pm
johnny21 wrote:T2 airport hotel
YUK.:mad: - What a mess. Who is responsible for this monument to a lack of imagination ?
Things like this would find difficulty getting planning permission in an industrial estate on the outskirts of Dusseldorf, yet our planners have no problem allowing such a monolithic, illiterate and mundane structure to grace the principal entry point to the country.
First impressions last, and anyone arriving into Dublin airport for the first time would probably pass this place by under the assumption that it is just another office block in the airport complex. A lost opportunity.
Global Citizen
Postby Global Citizen » Thu Dec 04, 2008 8:15 pm
The post I submitted above refers to an image for a new airport hotel submitted by "johnny21" on 25/07/2008.
Global Citizen
Postby johnglas » Fri Dec 05, 2008 11:16 am
Whew! that's a relief! I thought the new terminal looked suitably bloated and corporate as I approached it on Aircoach (and I thought the 'old' treminal environs had been greatly improved by recent works). It's virtually impossible to read the airport as an entity, but that doesn't mean it's all bad - and, for me at least, it all worked, which is all that I ask of an airport. Sometimes, they are an aesthetic experience (cf. Cork, Palma), but the railway stations of the 21st C they generally are not.
Postby Bluetonic » Sun Dec 14, 2008 6:46 pm
This site might be of interest.
http://www.daa4starhotelandmscp.com
Bluetonic
Postby johnglas » Sun Dec 14, 2008 11:39 pm
Yes, that does look awful and is an affront to any sense of aesthetics (and just when I thought m/s carparks were getting better). I presume the sticky-out tube does actually go somewhere and is not just for the vomitose effluent emitted by offended aesthetes.
Postby Bluetonic » Tue Dec 16, 2008 8:07 am
Of the two tubes, the one connected no nothing in the visual is not in the planning application. Presumably it's future pie in the sky to connect to the overground part of the adjacent Metro station.
Bluetonic
Postby Global Citizen » Wed Dec 17, 2008 11:33 pm
Anyone know what the story is with Corballis House?
I remember reading somewhere that it had to be rebuilt "brick by brick" elsewhere in order to make room for T2 as it was a protected building. Where is it now?
I always admired the way that the airport expanded over the years while the house stood untouched.
Global Citizen
Postby mrdarcy » Fri Dec 19, 2008 8:52 am
Corballis was demolished and is no longer with us except in memory and in pictures.:(
mrdarcy
