What happens if planning runs out
Postby iHaveAQuestion » Mon Nov 09, 2009 12:04 pm
Hi I have a simple planning question
I have planning permission on an old farmhouse for the installation of a septic tank and the refurbishment of the house.
Although I did not need planning for the house only for the septic tank, I applied for planning so that I could avail of the grants.
My question is should I enact the planning now... (It runs out next summer) and put in the septic tank
And do nothing to the house..., which is still standing and still has a roof on it.
What happens then next year when the planning runs out... can the council do anything to me as the house would still be intact with a roof on it… but still in disrepair.
Or am i better off just letting the planning lapse and doing the work the work to the house outside the planning system.... it is just fixing up the existing house.
iHaveAQuestion
Re: What happens if planning runs out
Postby markstephens » Mon Nov 09, 2009 12:57 pm
I'd put the tank in. Almost certainly the rules over the percolation test would have changes considerably since you got planning and to comply with planning now (if you needed a new application for whatever reason - neighbour complaint, to sell property etc...) you will have to provide additional test reports and calculations to meet current requirements (depending on County) These additional tests/reports will be an extra cost as well as time/effort/cost of the application itself) - you may also be asked to provide tests/calculations for the disposal of surface water (roofs etc...)
markstephens
Postby tommyt » Mon Nov 09, 2009 1:35 pm
iHaveAQuestion wrote:Hi I have a simple planning question
Your question is not that simple TBH. You would need to provide more factual info than is advisable on a public forum to get some definitive advice. Ring the planning authority or a planning consultant for an initial appraisal and have all yourr relevant info to hand.
