Neighbour seeking Reetention
Postby aimee » Mon Dec 08, 2008 3:12 pm
My neighbour received planning permission to extend his house a couple of years ago.
However, instead of extending his existing house,he demolished it and built a new one.
The new house, which is almost complete, is 230 square metres bigger than the house would have been if had he built it to the permission he received.
Naturally, the council have asked him to apply for retention, which he has done. In his application,
he applies for retention of 270 square meters. This is the difference between the original house and the new house. He also repeatedly compares the existing dwelling to the dwelling that he was granted permission for.
Eg. "the height of the house has not increased". (but it has increased by 3 meters compared to the original house)
My question, is whether he needs to apply for retention of 270 square meters, or for 400 square meters?
Should his retention compare the current built house to either:
a) the original house (270sqm to be retained)
b) the house as it would have been if he had built according to the original planning permission (210 sqm to be retained)
c) nothing, as he started building from scratch having demolished the existing building (400sqm to be retained)
Summary:
Original house = 130sqm
Planning received for extension of house. Extension size = 60sqm (Total house = 190sqm)
Original house completely demolished
New house built with floor area = 400sqm
I am trying to put together an objection, so want to have my fact right
Thanks very much.
Aimee
aimee
Re: Neighbour seeking Reetention
Postby henno » Mon Dec 08, 2008 3:22 pm
if he is only retaining 270 then the drawings must reflect that.... so i will assume that he is showning in this application that the 130 sq m original dwelling is still erect...??
if not he needs to retain the whole house as constructed....
Postby Archie » Tue Dec 09, 2008 3:05 am
aimee, out of curiosity why are you objecting to this?
Archie
Postby aimee » Tue Dec 09, 2008 9:00 am
Archie wrote:aimee, out of curiosity why are you objecting to this?
Hi ,
Thanks for your reply. On his drawings, he actually shows the as built house and also the outline of the house th received planning, which was never built.
I am objecting because our house, which is in the countryside and is old stlye, used to be a detached and out on its own with a little stone cottage beside it. It now has a massive modern 400sqm house built just meters away (our house which has been there for 150 years is just 5m from boundary wall and neighbour is 0.7m to the wall at the closest point. This was okay when it was just a little cottage, but given the large increase in height (1.7m compared with what was granted, I'm not sure what original cottage height was), it is completely overbearing. There are other issues like the neighbours windows that look straight into our bathroom and the devaluation to our house.
I'm not sure that my reasons would be strong enought to sway the planners as I am just one person so I am trying to get a good argument together. I am quite sure (having read the planning guidelines) that he has not complied with them (at all) as there are very strict guidelines for the area.
Thanks,
Niamh
Niamh
aimee
Postby forrestreid » Thu Dec 11, 2008 11:12 pm
What you are talking about in your objection is more of a complaint about the process of the planning application that your neighbour has, than an objection, as such.
My advice would be to separate your points clearly in your objection letter, in case the planner decides that your point about how much retention the applicant should have applied for is not worth pursuing with an additional information request (if the house is built as is more than 7 years, it is a bit of a moot point anyway).
E.g., say
1) This should be retention for x metres instead of y metres in the first place because...etc.
and then go on to:
2) Apart from that legal objection, his application is a bad idea because....
Also, you should make POSITIVE points in your letter rather than just whinge about it, e.g.: "my neighbour could improve the development if he moved his boiler x metres to the west...because...etc.
Also, avoid language like inferring that your house is an "old cottage" and your neighbours is an "ugly new bungalow" unless you have a valid conservation/heritage argument to make as it will just sound snobby, and that could irritate some types of planners.
forrestreid
Postby BTH » Fri Dec 12, 2008 12:37 am
If part of his new-build which is going for retention (ie not granted planning already) is only 0.7m from the boundary wall as you say he could be in breach of local development plan regulations which usually stipulate a minimum of 1.5m from boundary to house and often more in rural areas, although upon re-reading it sounds like the existing house was only 0.7m from the boundary to begin with. But of course the existing house was completely demolished and he'd never have gotten permission for a brand new house to be built that close to the boundary... hmmm. Sorry train of thought typing there.
Sounds like a fairly awful state of affairs. If right was right he should be made demolish whats been built but unfortunately that doesn't seem to happen in more rural local authority areas. This attitude of "ah sure they'll never make us demolish it, lets just fire away and do what we want and feck the neighbours" needs to be nipped in the bud.
Not much help I know but you have my sympathy.
Postby henno » Fri Dec 12, 2008 10:08 am
BTH wrote:If part of his new-build which is going for retention (ie not granted planning already) is only 0.7m from the boundary wall as you say he could be in breach of local development plan regulations which usually stipulate a minimum of 1.5m from boundary to house and often more in rural areas, although upon re-reading it sounds like the existing house was only 0.7m from the boundary to begin with. But of course the existing house was completely demolished and he'd never have gotten permission for a brand new house to be built that close to the boundary... hmmm. Sorry train of thought typing there.
this will, in the very near future...
there is legislation being written up to remove the 7 year statute of limitations on unauthorised developments.....
how exactly it will be worded im not sure... but theres a possibility every unauthorised development could be subject to enforcement action....
Postby Archie » Sat Dec 13, 2008 7:47 pm
aimee wrote:It now has a massive modern 400sqm house built just meters away (our house which has been there for 150 years is just 5m from boundary wall and neighbour is 0.7m to the wall at the closest point. This was okay when it was just a little cottage, but given the large increase in height (1.7m compared with what was granted, I'm not sure what original cottage height was), it is completely overbearing. There are other issues like the neighbours windows that look straight into our bathroom and the devaluation to our house.
But why did you not report this to the Planning Authority during the construction?
Archie
Postby aimee » Tue Dec 16, 2008 2:33 pm
Archie wrote:But why did you not report this to the Planning Authority during the construction?
I wasn't living in the house at the time as was having some work done on my own house (with full planning permission!). The neighbours house went up very quickly. But yes, I should have realised something was amiss.
aimee
Postby Archie » Tue Dec 16, 2008 6:19 pm
aimee wrote:I wasn't living in the house at the time as was having some work done on my own house (with full planning permission!). The neighbours house went up very quickly. But yes, I should have realised something was amiss.
Dont get me wrong here aimee as Im not having a go. I just fail to understand how your neighbour could have carried out this development without you realising it. You may not have been living in your house at the time but Im sure you visited often enough and you would have seen all this work in progress.
Even when the neighbour made a planning application you surely would have checked it out and when the works commenced you definitely could not have missed it given the sheer bulk involved. I find it all very strange that you wait until now before deciding to do anything about it. I just suspect that there are other reasons behind this.
For personal reasons I never get involved in objections and that is why I am so sceptical as to the reasons behind your objection.
Archie
