Elevated Exempt Extension
Postby leomel » Sun May 21, 2006 3:43 pm
Our neighbour has built an exempt single-storey extension which has French doors facing our property. Their floor level is about 8 feet higher than ours so these French doors are entirely above the level of our fence and almost in line with our upstairs window. They directly overlook our garden and living room (also French doors). They have also built a separate garage. The Planning Department fwere no help as on paper it is exempt, but the regulations do not take the elevation into account. We may have to resort to building something ourselves to regain some privacy but is there no protection for the existing people, or is it all in favour of "develop at all costs"?
leomel
Re: Elevated Exempt Extension
Postby Group Hug » Tue May 23, 2006 10:01 am
Put a washing line up and hang the most awful bloomers and gareish patterned sheets from it. You know what I mean. What a view! :D
Group Hug
Postby clear » Thu May 25, 2006 6:35 pm
What area are you in?
Check your county development plan. If you live within an urban boundary, then your county development plan more that likely will state something about screening between properties for privacy.
Also are you sure that its exempted development. If the extension is on the ground floor, then it can be 40 sq meters. If it is on an upper floor, I think there is a cap at 12 sq meters! If they have also built a seperate garage, not attached to the house then the limit for exempted development is around 25 sq meters and the elevated extension may not be therefore exempted. i.e. if you have used up your exempted allowence, you don't get more!
Write to the local authority asking for clarification that the development carried out was in fact exempted!
clear
