The Great Pyramid: metamorphose of the architecture
Re: The Great Pyramid: metamorphose of the architecture
GREAT PYRAMID, JERUSALEM AND THE SUN
Figure 1. The Sun, Moon and the Earth; The GreatPyramid (Giza) and Jerusalem (distances are not drawn to scale).
Latitude:
Great Pyramid = 30º N
Jerusalem = 31,7972159º N
31,7972159 - 30 = 1,7972159º = A-B (Figure 1.).
On the curved Earth's surface 1º = 111 km:
1,7972159º = 199,4909649 km = A-B.
One side of the Pyramid's base = 365,242 Saced ubits = 0,23192867 km.
Four sides of the Pyramid's base = 0,92771468 km = B-C (Figure 1.):
0,92771468 : 199,4909649 = 0,00465041 = tangent of the agle β (Figure 1-2.)
Figure 2. Ecliptic of the Sun (the dimensions of bodies and distances are not drawn to scale).
The distance from the Earth to the Sun = 149.597.870 km = 1 Astrononical Unit ( 1 AU) = S-E (Figure 2).
149.597870 x 0,00465041 = 695.691,4306 km = R = radius of the Sun.
Radius of the Moon = 1738 km:
1738 : 0,00465041 = 373.730,4883 km = the distance from the Earth to the Moon.
Four sides of the Pyramid's base = 4 x 365,242 = 1460,968 Sacred Cubits:
1460,968 : 0,00465041 = 314.159 Sared Cubits = 100.000 x 3,14159 (100.000Pi) = 199,4909438 km = A-B (Figure 1.).
Jerusalem (latitude):
http://www.timeanddate.com/worldclock/city.html?n=110
http://www.realestate3d.com/gps/world-latlong.htm
Distance of the Moon:
http://www.eso.org/public/outreach/press-rel/pr-2002/phot-19-02.html
http://www.tmclark.com/Starwatch/10_26_98.html
Latitude:
Vidusa - Member
THE SUN AND SOLOMON'S TEMPLE
The arth, Moon, Sun adn the Solomon's temple
"And thus Solomon began to build the house of God: the length in cubits - even the first measurement from end to end, was sixty cubits, and the breadth twenty cubits.
And the portico in front of the house, its length in front of the breadth of the house was twenty cubits, and its height a hundred and twenty cubits." (II Chron. 2, 3 - Septuagint v.)
(B-C) = 120 Sacred Cubits (the first measurement from end to end) = 7620 cm.
Tangent of the angle β = 0,00465041.
Height of the Great Pyramid = 14.765,05019 cm
14.765,05019 : 10.000 = 1,476505019 cm
If a certain object was to travel with a speed of 1,476505019 cm/hour, for 24 hours ( one day) it would travel a distance of 35,43612046 cm:
35,43612046 : 0,00465041 = 7620 cm = 120 Sacred Cubits = B-C = the height of the portico of the Solomon's temple.
35,43612046 x 10 = 354,3612046 = days of the lunar year.
35,43612046 x 18,000.000 = 6378,501683 km = Earth's equatorial radius.
Earth's equatorial diameter = 12.757,00336 km = 1.275.700.336 cm:
1.275.700.336 : 35,43612046 = 1/36.000.000 parth of the Earth's equatorial diameter.
With the speed of 35,43612046 cm/sec., for one minute (60 seconds) a certain object was to travel a distance of 127.570,0337 cm = 1/10.000 parth of the Earth's equatorial diameter.
Vidusa - Member
BOAZ AND JACHIN
Boaz and Jachin, two pillars, stood in the porch of Solomon's Temple.
Boaz and Jachin:
Height = 27 Sacred Cubits = 1714.5 cm
2 x 54 Sacred Cubits = 3429 cm
3429 x 0,00465041 = 15,94625589 cm
4 x 15,94625589 = 63,78502356 cm
15,94625589 x 40,000.000 = 6378,502356 km = Earth's equatorial radius.
8 x 15,94625589 cm = 127,5700471 cm = 1/10.000.000 parth of the Earth's equatorial diameter.
Boaz and Jachin:
Vidusa - Member
SOLOMON'S SEA
Sun's parallax and the Brazen Sea in Solomon's Temple
"He made the Sea of cast metal, circular in shape, measuring ten cubits from rim to rim and five cubits high. It took a line of thirty cubits to measure around it."
"The Sea stood on twelvw bulls..."
Diameter of the Sea = 10 Saced Cubits = 635 cm:
635 x 3,14159 = 1994,90965 cm
1994,90965 x 0,00465041 = 9,277147785 cm
12 bulls = 12 parts:
9,277147785 : 12 = 0,773095649 cm
If a certain object was to travel with a speed of 0,773095649 cm/sek., for ne minut it would travel a distance of 46,38573893 cm: two sides of the Pyramid's base = 46.385,734 cm
Circumence of the Sea (around) = 30 Sacred Cubits = 1905 cm:
1905 x 0,00465041 = 8,85903105 cm: If a certain object was to travel with a speed of 8,85903105 cm/min., for 24 hours it would travel a distance of 12.757,00471 cm: equatorial diameter of the Earth = 12.757,00336 km.
Around the Sea = 30 Sacred Cubits = 1905 cm
30 : 3,14159 = 9,549304651 Sacred Cubits = 606,3808454 cm
606,3808454 x 0,00465041 = 2,819919547 cm: If a certain object was to travel with a speed of 2,819919547 cm/min., for 24 hours it would travel a distance of 4060,684148 cm.
Tangent of the angle of King's Chamber north "air" channel = 0,63662031
4060,684148 cm : 0,63662031 = 6378,502357 cm: equatorial radius of the Earth = 6378,50168 km.4060,684148 x 3,14159 = 12.757,00471 cm: Earth's equatorial diameter = 12.757,00336 km.
Distance from rim to rim = 10 Sacred Cubits = 63,5 cm.
635 x 0,00465041 = 2,953010035 cm = 2 x 1,476505018 cm = 1/10.000 of the Pyramid's height.
Vidusa - Member
- shamrockmetro
LOUVRE GLASS PYRAMID
Glass pyramid, Louvre, Paris
Time of the building: 1987- 1989
Completed in 1989
French Revolution: 14 july 1789
1789 -1989 = 200 years
Pyramid's code: 1 Sacred Cubit = 20,19176875 years (templars metod of the building):
14 july 1789 = 1788,5397 AD = 88,57766362 Sacred Cubits = 5.624,68164 = 56,2468166 meters
Louvre Glass pyramid:
http://www.erco.com/en_index.htm?http://www.erco.com/projects/museum/louvre_glas_2307/en/en_louvre_glas_facts_1.htm
Height of pyramid: 21.65m
Length of pyramid base: 35m
Inclination of sides: 51.7 degrees
Total: 56,65 m (???)
56,65 m = 5665 cm = 89.07086614 Sacred Cubits :
89.07086614 x 20,19176875 = 1801.1360157 year AD
The Louvre Glass pyramid = memorial monument to the French Revolution 1789 AD.
Completed in 1989
Vidusa - Member
Vidusa - Member
ORION AND THE THREE PYRAMIDS
91 units (“rooms”)
The three pyramids of Giza are located on Earth just as the three stars in the belt of Orion.
From the western side of the middle pyramid, that corresponds to the middle star of Orion’s belt, Alnilam (ε Ori), there are [B]91 units (“rooms”).
These units show that this star will be by 91º away (1 unit = 1º ) from North celestial pole at the time of the End of the World.
Current position is very close to 91º.[/B]
http://server1.sky-map.org/starImageView.jsp?image_id=109&show_box=1&box_ra=5.636563153672021&box_de=-0.39669947100416
91 units (“rooms”)
Vidusa - Member
WASHINGTON MONUMENT (II)
"At 555 feet 5 1/8 inches (169.29 meters) high, the Washington Monument towers over everything in Washington, DC and is one of the tallest masonry structures in the world.
The cornerstone for the monument was laid on July 4, 1848, and the monument was opened to the public on October 9, 1888. In total, there are 36,491 stones."
http://bensguide.gpo.gov/3-5/symbols/wa_monument.html
555 feet 5 1/8 inches = 6665.125 inches = 16.929.4175 centimeters
Washington Monument = 36.491 stones:
a) 6665.125 : 36491 = 0,182651202 inches
b) 16.929.4175 : 36491 = 0.463934052 cm
Two sides of the Great Pyramid's base = 730.428 Sacred Cubits = 18.262.1 inches = 46.385.734 cm
46.385.734 x 36.491 = 1.692.661.819 cm = 16.926.61819 km
Vidusa - Member
WASHINGTON MONUMENT (III)
Facts and Symbolism about the Washington Monument:
Height = 555 feet 5 1/8 inches = 6665.125 inches
Number of blocks in monument 36,491
Cornerstone laid: July 4, 1848 = 1847.426 year A.D.
Capstone set: December 6, 1884 = 1883.931 year A.D.
Symbolism: 36,491 blocks = 36.491 years (1000 blocks = 1 year)
1883.931 - 36.491 =1847.44 year A.D. = July 9, 1848 (cornerstone laid: July 4, 1848)
36.491 years = 13,328.04582 days
13,328.04582 : 2 = 6664.022911 days
6664.022911 inches = 555.3352426 feet = 555 feet 4.023 inches
Vidusa - Member
1 STONE = 1 DAY
"Man fears Time, yet Time fears the Pyramids" ~ Arabian proverb
Washington monument = 36,491 stones:
36,491 days = 99.90910136 years = 100 years = 1 century
The Great Pyramid = 2,300,000 blocks of stone:
2,300,000 days = 6297.194737 years (according to the biblical chronology = 2016 AD)
Vidusa - Member
WASHINGTON MONUMENT (IV)
Solar pyramidion (4. July)
The cornerstone for the Washington Monument was laid on July 4, 1848,
On 4 July the Earth is at aphelion, about 152,000,000 km from the Sun.
Earth (diameter) = 12,757.00336 km
Sun (diameter) = 139,200 km
139,200 : 12,757.00336 = 109.1165347 km
139,200 x 109.1165347 = 151,890,216.3 km = E-S = 4. July
β = 72.73246551º
Tangent β = 3.217049576
151,890,216.3 : 3.217049576 = 47,214,136.04 km = A-E = E-B
George Washington: Februaru 22, 1732 - December 14, 1799
Sun (radius) = 696,000 km
A-E = 47,214,136.04 km
47,214,136.04 : 696,000 = 67.83640234 km = 67.83640234 years = G. Washington's life (1 km = 1 year).
The Washington Monument (height) = 555 feet, 5 1/8 inches = 169,294.175 millimeters. It had 898 steps to the level of the windows at 500 feet.
Today the monument has only 897 steps (the bottom one has been converted to a wheelchair ramp).
A-E = 151,890,216.3 km:
151,890,216.3 : 169,294.175 = 897.1969431
169,294.175 x 898 = 152,026,169.2
169,294.175 x 897 = 151,856,875
β = 72.73246551º
Vidusa - Member
MEASUREMENTS AND THE MEASURERS
The Great Pyramid: from the Pyramid's base to the floor of the King's Chamber = 1699.508338 inches = 4316.751179 cm.
The Earth: from the equator to the Washington Monument = 169,949,330.2 inches = 4316.712986 km = 38.88930618º = 38º 53' 21.50225916" N.
"The Washington Monument, in Washington, DC, is located 38°53'21.5" north of the equator..."
http://www.astronomicalfacts.com/article.html
Vidusa - Member
ISS
The ISS orbits the Earth at 51.5947° to the Equator (tangent of the angle = 1.261446274).
Equator = 40.077,27418 km:
ISS orbital altitude at perigee = 361 km
40.077,27418 : 361 = 111,01738 km (1° = 111 km)
361 : 1,261446274 = 286,1794499 km (the entrance axis is located away from the main axis of the Great Pyramid by 286.4690182 inches).
* http://www.space.gc.ca/asc/pdf/educator-observing_edu.pdf
Vidusa - Member
LOUVRE GLASS PYRAMID (II)
Commissioned by the French president François Mitterrand, it was designed by the architect I. M. Pei from New York. Spectacular in concept and form, they provide a startling reminder of the audacious ability of modern architects to invigorate and re-circulate traditional architectural forms.
Louvre: four sides of the Cent Carree (literally `square courtyard') at the eastern end of the building. The split level public area under the glass pyramid is known as the Hall Napoleon (Napoleon's height and his flag: 160 (x 160) cm, close to year-geometry, right).
It is not well known that a baroque pyramid was proposed for the centennial celebrations of the 1789 French Revolution. It is possible that the architect, I. M. Pei, was aware of these designs when he chose a pyramid form, for the bicentennial celebrations of 1989.
French Revolution: 14 July 1789
14 july 1789 = 1788,5397 AD = 88,57766362 Sacred Cubits = 5.624,68164 = 56,2468166 meters.
1788,5397 + 200 = 1988.5397 years = 14 July 1989
1988.5397 : 3.14159 = 632.9723802 = diameter of the circle A
Area of the circle A = 314,672.6768 units² = area of the square B
One side of the square B = 560.9569295 units
560.9569295 : 8 = 70.11961619 units = 70.11961619 meters = one side of the square T
One side of the square S = 49.5820561 meters
One side of the square P = 35.05980809 meters = length of the Glass Pyramid's base.
56,2468166 - 35.05980809 = 21.18700851 meters = height of the Glass Pyramid**.
* Napoleon's French Empire in Italy (flag):
http://en.wikipedia.org/wiki/Italian_Republic_%28Napoleonic%29
** Glass Pyramid (height):
http://www.franceattraction.com/louvre-museum-paris-france.html
Vidusa - Member
Vidusa - Member
The New Great Pyramid
http://news.bbc.co.uk/1/hi/world/europe/7289973.stm
THE GREAT PYRAMID - EARTH = 1 : 43 200
Figure 1
1.
A-B = 365.242 Sacred Cubits = 9131.05 inches = 231.92867 m = 0.23192867 km
4A-B = square D = 0.92771468 km:
0.92771468 x 43 200 = 40 077.27418 km = Earth's equator
2.
H = 232.5204754 Sacred Cubits = 5813.011885 inches = 147.6505019 m:
147.6505019 m x 43 200 = 6378.501681 km = Earth's equatorial radius
3.
H = radius of the circle E = 147.6505019 m
Area E = 68 488.7691 m2 = Area C
√68 488.7691 = 261.7035902 m = one side of the square C
261.7035902 m x 43 200 = 11 305.59509 km
Figure 2
Side c of the square B (Figure 2) =11 305.59509 km
Area of the square B = 12,7816,480.3 km2 = Area of the crcle A = Area of the Earth's circle
Diameter of the circle A = 12757,00336 km = Earth's equatorial diameter = d
4.
One side of the square C (Figure 1) = 261.7035902 m = radius of te circle F
Area of the circle F = 53 790.90805 m2 = Area of the square D
√53 790.90805 = 231.9286702 m = A-B
5.
11 305.59509 : 43 200 = 261.35901 m = 412.131638 Sacred Cubits = 10 303.29095 inches = 25 lengths of the King's Chamber = 50 widths of the King's Chamber
Figure 1
1.
2.
3.
Figure 2
4.
5.
Vidusa - Member
EARTH, SOLOMON’S TEMPLE AND THE PYRAMID
Earth’s Equator = 40,077.27418 km = Circle A
Circle A = Earth
d = Equatorial diameter of the Earth = 12,757.00336 km
Area = 127,816,480.3 km²
Square B :
Area = 127,816,480.3 km² = area of the circle A
Side C = 11,305.59509 km = 1,130,559,509 cm.
Thomas Ustick Walter: Solomon's temple
Solomon’s temple:
Portal (high) = 120 Sacred Cubits
Length = 60 “ “
Width = 20 “ “
Height = 30 “ “
The numbers of the Temple are the code:
- Number 120
- Number 60
- Number 30
- Number 20
a) 1,130,559,509 : 120 = 9,421,329.241 cm
b) 9,421,329.241 : 60 = 157,022.154 cm
c) 157,022.154 : 30 = 5,234.071801 cm = 2,060.658189 inches
d){/} 5,234.071801 : 20 = 261.70359 cm = [B]103.0329095 inches
The Great Pyramid:
King’s Chamber:
- Length = 412.1316378 inches
- Width = 206.0658189 inches
- 1/2 of the Chamber’s width = 103.0329095 inches
Solomon's temple:
http://www.philaathenaeum.org/tuw/ancient.html
Circle A = Earth
Square B :
Solomon’s temple:
Length = 60 “ “
Width = 20 “ “
Height = 30 “ “
- Number 120
- Number 60
- Number 30
- Number 20
The Great Pyramid:
King’s Chamber:
Solomon's temple:
Vidusa - Member
CIRCLE OF THE NUMBERS
I) The Great Pyramid's angle of ascent = 51.85399755 degrees:
tangent = 1.273240621
1.273240621 : 4 = 0.318310155
Solomon’s temple:
-portal (high) = 120 Sacred Cubits
-length = 60...... “...........“
-width = 20...... “........... “
-height = 30...... “........... “
0.318310155 x 120 x 60 x 30 x 20 = 1,375,099.871
1,375,099.871 x 3.14159 = 4,320,000
II) Earth's equatorial diameter = 12,757.00336 km = 502,244,226.8 inches:
502,244,226.8 : 4,320,000 = 116.2602377 inches = length of the Great Pyramid's Antechamber.
III) 4,320,000 : 1.273240621 = 3,392,917.198
3,392,917.198 : 120 : 60 : 30 : 20 = 0.7853975 = Pi/4
IV) √1.273240621 = 1.128379644
Earth's equator = 40,077.27418 km:
1.128379644 x 40,077.27418 = 45,222.38035 km = 1,780,408,675 inches:
1,780,408,675 : 120 : 60 : 30 : 20 = 412.1316378 inches = length of the Pyramid's King's Chamber.
V) Angle of ascent of the North King's Chamber air-channel = 32.48165854 degrees:
tangent = 0.63662031
1.273240621 : 2 = 0.63662031
0.63662031 x 40,077.27418 = 25,514.00671 km = 40,179,538.13 Sacred Cubits:
1,004,488,453 : 120 : 60 : 30 : 20 = 232.5204753 Sacred Cubits = height of the Great Pyramid.
Solomon’s temple:
Vidusa - Member
Vidusa wrote:METAMORPHOSE OF THE PYRAMID'S ARCHITECTURE
Sacred Cubit
The English have a measurement of length, which they call skein : 109,728 meters.
If a man was walk one day, with his every step 1 Sacred Cubit (63,5 cm) and with the speed of two steps in a second (2 Sacred Cubits or 127 cm), in 24 hours he would travel 109,728 km (1.000 skeins). For one year of 365,242 days, he would travel around the planet Earth. That is, he would travel the length of the Equator: 40.077,27418 km:
Some university maths departments famously used to have a form for filling out sending to people who wrote in to them which read "Dear . . . , Many thanks for your proof of the . . . theorem, the first error occurs at line . . . .". When I was in Cambridge we used to get wonderful false proofs, the highlight being a careful and detailed book of "ufo observations" illustrated and written in crayon. I wish I had kept it, it had a certain integrity as a piece of folk art, as it was it was probably thrown out. We also used to get a lot of pyramid letters, now, I am much more tolerant of this sort of thing than most scientists, but I only got as far as your first paragraph before finding an error
127cmX60X60X24=109728 cm, not km and not meters as you claim for the skein: in fact, a skein is a measure of yarn length, according to Wikipedia it is 80 turns of a 54 inch bobbin or some such.
notjim wrote:Some university maths departments famously used to have a form for filling out sending to people who wrote in to them which read "Dear . . . , Many thanks for your proof of the . . . theorem, the first error occurs at line . . . .". When I was in Cambridge we used to get wonderful false proofs, the highlight being a careful and detailed book of "ufo observations" illustrated and written in crayon. I wish I had kept it, it had a certain integrity as a piece of folk art, as it was it was probably thrown out. We also used to get a lot of pyramid letters, now, I am much more tolerant of this sort of thing than most scientists, but I only got as far as your first paragraph before finding an error
Vidusa: Sacred Cubit
Excuse me, please:
127cm x 60" x 60' x 24 hours = 10,972,800cm = 109.728km
Skein:
http://orefa.org/length.html
http://www.onlineunitconversion.com/cape.rood_to_football.field.U.S.html
http://www.themeter.net/lung_e.htm
http://www.convertit.com/Go/Entisoft/Measurement/Converter.ASP
Thank you and all the best!
Vidusa - Member
So either my screen or your conventions is switching commas and dots; if I had read further I would have realised you were using dots for thousands and commas for decimals so you win that one. However, I still don't get it, nor, I am afraid have I been able to read further, can you give me a _three line summary_ of what all these numbers are supposed to be doing, is the basic idea that the dimensions of some pyramids are in surprising ratio to dimensions found elsewhere?
I remain skeptical about the skein, it seems to have lots of different lengths in different definitions; the cubit is also a very variable length, usually shorter than the cubit you use, for example, the Egyptian cubit is 52.5 cm, many of the internal dimensions of the Great Pyramid are whole numbers in Egyptian cubits.
I am sorry to appear skeptical, that is because I am skeptical, I am, however, willing to bet I am the first person to try to check any of your calculations.
Sacred Cubit = 63.5cm
Amah = Sacred Cubit
Amah =Hamah = one of the three words for the Sun
Radius of the Sun (R) = 695,691.4306 km
Tangent β = 0.00465041
Length A-C = 1 sacred cubit = 63.5cm
Earth's equator (length) = 40,077.27418 km
Equator = circle= 360 degrees = 21,600 minutes
40,077.27418 : 21,600 = 1.85542936 km
1 degree (Equator) = 1.85542936 km
1 : 100.000 = 1 cm on the particular drawing = 100.000 cm in the realty
A-C = 1 sacred cubit = 25 inches = 63.5 cm
Circle Z (circumference) = 1.85542936 cm
Diameter of the circle Z = 0.590602007 cm
Radius (R) of the circle Z = 0.295301004 cm
0.295301004 : 2 = 0.147650502 cm = 1/100,000 of the G. Pyramid's height
0.295301004 : 63.5 = 0.00465041 = tangent β
Sacred cubit was created from the Earth's and the Sun's measurements.
"It may be of interest, albeit of no halakhic import, to note that, based upon Josephus’ description of the circumference of the pillars of the Temple, the renowned physicist Sir Isaac Newton postulated the length of the “sacred” cubit to be between 24.90 and 25.02 inches as distinct from the “profane” cubit of 20.63 inches that he believed was the measurement employed by the Egyptians in construction of the Great Pyramid. Newton’s calculations are the subject of his “De magnitudine cubiti sacri.” An English translation of that essay titled “A Dissertation Upon the Sacred Cubit of the Jews and the Cubit of Several Nations: in which, from the Dimensions of the Greatest Pyramid, as taken by Mr. John Greaves, the ancient Cubit of Memphis is determined” was published in the Miscellaneous Works of John Greaves, Professor of Astronomy in the University of Oxford, ed. Thomas Birch, II (London, 1737), 405-433."
http://www.traditiononline.org/news/art ... ?id=100741
"18. For a comprehensive survey of the bases and ramifications of those opinions see R. Jacob Gershon Weiss, Midot u-Mishkalot shel Torah (Jerusalem, 5745), pp. 198-264.
19. R. Abraham Chaim Noe, Shi’urei Torah (Jerusalem, 5707), p. 249, calculates the amah, or cubit, as 48 centimeters (18.897 inches). The identical calculation was earlier advanced by R. Shalom Mordecai Schwadron, Da’at Torah 35:116, and Darkei Teshuvah 19:27. Accordingly, the mil, which equals 2,000 cubits, is equal to a distance of 960 meters (3,149.60 feet). Rabbi Noe gives alternative calculations of the amah as equal to 47 centimeters (18.5 inches) or 49 centimeters (19.29 inches). The mil would then be the equivalent of 940 (3,083.98 feet) or 980 meters (3,215.22 feet).
20. Hazon Ish, Kuntres ha-Shi’urin, Orah Hayyim: Mo’ed 39:5-6, and 39:9, calculates the amah as 58 centimeters (22.83 inches) and, accordingly, a mil would equal 1,160 meters (3,805.77 feet). Hazon Ish also cites a report to the effect that R. Shmu’el Salant accepted calculations that would render the amah 60 centimeters or 23.62 inches and the mil 1200 meters or 3937.01 feet. Nevertheless, for purposes of stringency, R. Shmu’el Salant is reported to have accepted calculation that would yield 48 centimeters or 18.90 inches for the amah and 960 meters or 3149.61 feet for the mil.
Cf., R. Ya’akov Kanievsky, Shi’urin shel Torah (Bnei Brak, 5729), who, in a note on p. 63, calculates the amah as 57 2/3 centimeters (22.70 inches) and possibly, according to Rashba, as 59.66 centimeters (23.49 inches). The mil would then be the equivalent of either a bit more than 1,153.2 meters (3,783.46 feet) or a bit more than 1,193.2 meters (3,914.6 feet). Actually, according to Rabbi Kanievsky’s own premises, the calculation of the amah as 57 2/3 centimeters is somewhat imprecise. Rabbi Kanievsky reports that “according to that which has been received by us from gedolei hora’ah, that the amah equals 13 vershak . . .” The vershak is a Russian measuring length equal to 1.75 inches or 4.445 centimeters. If so an amah is the equivalent of 57.78 centimeters (22.73 inches) and thus a mil is equal to 1,155.7 meters (3,791.66 feet). See Encylopedia Britannica, 15th ed. (Chicago, 1995), XIX, 735 (where the term is transliterated as verchok).
A table compiled by Moshe, Rosa and Shimon Bodenheimmer, Shi’urin u-Middot Hazal (Jerusalem, 5725), gives the measurement of the amah as 57.6 centimeters (22.67 inches). Cf., the table published by Y. Avi-Zevi, Shanah be-Shanah, 5730, p. 125, that gives the measurement of the amah as 56 centimeters and that of the mil as 1120.37 meters. Those measurements presumably reflect the view of R. Chaim Jacob Sheftel, Erekh Milin (Berditchev, 5667), erekh ezba, according to whom the amah measures approximately 56 centimeters. See Encyclopedia Talmudit, II (Jerusalem, 5760), 29, note 56.
Other less frequently cited opinions with regard to the length of an amah include those of Meshiv Davar, I, no. 24; Arukh ha-Shulhan, Yoreh De’ah 201:3; Teshuvot Hatam Sofer, Orah Hayyim, no. 181; and the earlier noted view of Erekh Milin, erekh ezba.
Meshiv Davar rejects what he terms “the customarily accepted calculations” according to which the length of the amah would equal 60 centimeters and advances considerations that would yield the measurement of an amah as 48 centimeters. Nevertheless, in his concluding remarks he retracts that view and advances a calculation that would result in an amah measured “in excess of” 48 centimeters and endorses the practice of Frankfurt am Main according to which the length of the amah is calculated as 57 centimeters or 22.44 inches.
Arukh ha-Shulhan states that the length of an amah is 12 “veierskes,” which is apparently the Yiddish term for the Russian vershak. Thus, according to Arukh ha-Shulhan, the length of an amah equals 53.34 centimeters or 21.0 inches. Cf., Encylopedia Talmudit, II, 29, where the length of an amah is given as 54 centimeters according to Arukh ha-Shulhan.
Teshuvot Hatam Sofer states that the length of a fingerwidth is a “zoll.” Since a biblical amah is equal to 24 fingerwidths, the length of an amah according to Hatam Sofer equals 24 zoll. Da’at Torah, Yoreh De’ah, Kuntres Aharon 35:116 states that the zoll is equal to 2.6 centimeters. That calculation is apparently also assumed by Darkei Teshuvah and Encyclopedia Talmudit. [Cf., however, Encyclopedia Britannica, loc. cit., which describes the zoll as a Swiss unit of measure equal to 3 centimeters.] Encyclopedia Talmudit, ad locum, indicates that, according to Hatam Sofer, the length of an amah is 62.4 centimeters or 24.567 inches. Thus a mil, according to Hatam Sofer, would equal 1248.0 meters or 4094.49 feet. Darkei Teshuvah 19:27 notes that the amah was marginally enlarged by rabbinic decree and, accordingly, should be calculated as 241/2 zoll. Darkei Teshuvah endorses the position of Hatam Sofer and states that the length of an amah according to Hatam Sofer is 63.8 centimeters. Thus, according to Darkei Teshuvah, an amah equals 25.12 inches and, accordingly, a mil equals 1276 meters or 4186.35 feet. Hatam Sofer’s calculations are thus significantly greater than those of the earlier-cited authorities.
Darkei Teshuvot also cites a certain “Rabbi of Yasi” who calculated the amah as “no more than” 52 or 53 centimeters and an anonymous scholar who differed and calculated the amah as approximately 581/2 centimeters. Darkei Teshuvah also quotes She’erit Yisra’el, Parashat Mezora, who calculates the amah as 211/6 zoll or 56 centimeters and further opines that one who calculates the amah as 221/8 zoll or 57 centimeters is to be commended. Darkei Teshuvah cites an additional source for the latter calculation as well.
Da’at Torah, Yoreh De’ah, Kuntres Aharon 35:116, cites authorities who variously posit the length of an amah as 47 centimeters, 55.25 centimeters, a bit more than 57 centimeters and 58.5 centimeters, as well as one authority who asserts that according to Rashi the amah equals 43.8 centimeters, according to Shakh 45.02 centimeters, according to Taz 47.34 centimeters and according to Rambam 50 centimeters. See also the measurements ascribed to earlier authorities by Rabbi Weiss, Midot u- Mishkalot shel Torah, pp. 198-264 as well as the table presented ibid., introduction, p. 8. See also R. Moshe Shimshon Bacharach, Hut ha- Shani, no. 97.
For a table correlating many of these measurements of the amah with the volume of the liquid revi’it see Midot u-Mishkalot shel Torah, introd., p. 8. Rabbi Kanievsky, Shi’urin shel Torah, p. 51, cites a discussion in the Palestinian Talmud, Terumot 10:7, that is understood by some authorities, including Riva, Commentary on the Pentateuch, Parashat Mishpatim; Ma’adanei Yom Tov, Berakhot 3:30; and Tosafot Yom Tov, Pe’ah 6:6, as indicating that a revi’it equals 240 grams. If so, an amah would appear to equal 73.368 centimeters or 28.885 inches. Rabbi Kanievsky categorizes that calculation of the revi’it as “extremely large” and as “not imagined by earlyday authorities.”
http://www.traditiononline.org/news/art[/url] ... ?id=100741
Amah = Sacred Cubit
Vidusa - Member
Well perhaps the easiest thing is to restrict our interest to dimensionless claims, claims based on the ratios of distances rather than on the distances themselves: few historic units have universal definitions and it is hard to agree based on internet sources since it is impossible for us to verify their impartiality.
